Unknown usage for ground under/behind cluster
Re: Unknown usage for ground under/behind cluster (aenima_20)
i wouldnt worry about it...all grounds are put there for a reason....if you remove it just put it back
Re: Unknown usage for ground under/behind cluster (96civich22)
the ground doesnt go anywhere!
the other end that is not connected to the chassis doesnt go to anything like the stereo or something
thats what im trying to find out
where does the other end of this ground should plug in
Re: Unknown usage for ground under/behind cluster (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">so its cut and just hangs there?</TD></TR></TABLE>
yeah, I wanna plug everything back properly
I just recently had a problem when I left mine unplugged and it didnt allow my tail lights to be on. A better description would be that my tail lights worked but they wouldnt be on when I turned my lights on, only when I applied the brakes. I dunno what anyone else went through if/when they left theirs unplugged but thats my experience.
Re: Unknown usage for ground under/behind cluster (Falkien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falkien »</TD></TR><TR><TD CLASS="quote">I just recently had a problem when I left mine unplugged and it didnt allow my tail lights to be on. A better description would be that my tail lights worked but they wouldnt be on when I turned my lights on, only when I applied the brakes. I dunno what anyone else went through if/when they left theirs unplugged but thats my experience. </TD></TR></TABLE>
thanks man
at least I now know for sure it has to do with the lights
thanks man
is it possible this would be the ground for the stereo ?
the wire has 2 silver spots every inch or so
Re: (ctr610)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr610 »</TD></TR><TR><TD CLASS="quote">its for the head unit</TD></TR></TABLE>
Correct!!! I forgot to put this back when I did my black interior conversion (dash swap) and my radio didn't work. Plugged it in and it worked.
I am a (Trial User) Army
Re: Unknown usage for ground under/behind cluster (Hello Bart)
This ground is for the gauge cluster. It is linked up on the underdash harness.
The headunit grounds down by the lower center part of the dash.
At least it's like that on Teg's.
Re: Unknown usage for ground under/behind cluster (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">This ground is for the gauge cluster. It is linked up on the underdash harness.
At least it's like that on Teg's.</TD></TR></TABLE>
It was a ground for my headunit.
shivic
12-21-2006 08:07 AM
O16581724 5 2 5
09-18-2005 02:05 PM
crxman00
09-21-2003 09:08 PM
