Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny?
Like stated in the title says Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny? its going into a 93 civic ex coupe, if so can i still use the same ECU.
thanks in advance
thanks in advance
Re: Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny? (DJ_SaNdOz)
thanks , as for the ecu what would i use?
Some people say it does bolt on, some people say it doesn't. Flip a coin
As for the ECU, you will throw a few codes. (VTEC-related) It's not going to run the best, but it will run.
Re: Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny? (fast88std)
an auto LS ECU or an auto P06 should work....a little tuning would help them, but it woudl work just fine I'd think.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">an auto LS ECU or an auto P06 should work....a little tuning would help them, but it woudl work just fine I'd think.....</TD></TR></TABLE>Yep, hes right. forgot about the LS ecu.
Thanks, my brother is looking for a new motor for his fiance (hence the Auto) i hinted at this and i seems like a good idea and it different to pop the hood and see that....also its cheap
99sonicbluegsr
03-28-2005 05:01 PM
saucycivic
06-14-2001 09:03 PM
