How do I tighten my A/C belt? (Pictures included)
Old 08-26-2005, 08:54 AM
Tuesdaynightfever's Avatar
Default How do I tighten my A/C belt? (Pictures included)
Well, after reading a few threads on here, and being told a few times by friends...I believe I need to tighten my A/C belt. Sometimes when I shift and my A/C is on, it sounds like I have a BOV. Also, when it rains my A/C belt makes a high pitched noise (only when it rains or is damp out). My question is this: how do I tighten my A/C belt? I saw a few bolts around the belt, but am unsure of which one(s) to tighten, or how to go about this process in general. If anyone can let me know how to tighten my A/C belt, it would be greatly appreciated.
Old 08-26-2005, 09:15 AM
Senor Miembro
ecahatch's Avatar
adjust that bolt on the tensioner (the small wheel), the thing with the small wheel right below the bottom right hand side of the valve cover. the bolt facing down.
Old 08-26-2005, 09:19 AM
Is this the bolt you are talking about?
Old 08-26-2005, 09:30 AM
B18EG6's Avatar
Default Re: (Tuesdaynightfever)
no. The bolt at 11 o'clock from that bolt. Up and to the left a wee
Old 08-26-2005, 09:48 AM
Alright...so it would be this one...?
Sorry about the n00b question...better to be safe than sorry though. Also, he stated above that its the bolt on the wheel type thing...but the one I indicated in red isn't on the wheel type thing at all. Someone help this confused boy out!
Old 08-26-2005, 10:11 AM
Bizzump!
Old 08-26-2005, 10:18 AM
Andres-eh2's Avatar
its the other bolt! top right corner of the last pic
Old 08-26-2005, 10:21 AM
Luserkid's Avatar
Default Re: (Andres-eh2)
Old 08-26-2005, 10:35 AM
Thank you! From the problems I listed above...BOV sound and high pitched noise, would you say that it needs to be tightened? I've also heard of a high pitched noise resulting in being too tight. Anyone have any input? Thanks again!
Old 08-26-2005, 10:37 AM
Luserkid's Avatar
Put your finger on the belt, if you could press it and flip it around half way your fine. More flip more push needs tightening. no flip, hard push to tight.
I use to have that blow off valve sound too when i had AC you have the AC on and rev and it makes the noise? I think you need to replace your needle for the freyon because its leaking. Atleast that was my thought when i had it. never got it fixed.
Old 08-26-2005, 10:46 AM
Thanks man. My belt flips around almost half way. But, I still have that annoying high pitched sound when it rains or is damp out...and I know it is coming from my A/C belt, because when I turn on and off my A/C the pitch differs. Also, when I pop the hood it is quite obvious the sound is coming from that belt. So...if I can flip it almost half way, would you suggest loosening it a bit more? Also, the BOV sound isn't that big of a problem, I just wanted to state that I did hear this a few times...but it doesn't happen everytime I rev my car up.
Old 08-26-2005, 10:47 AM
Luserkid's Avatar
It wouldnt hurt to loosen it. But once you do its all trial and error. Tighten everything, start car, listen and repeat. But a little wont hurt.... just dont let it flip completely halfway thats to much.
Old 08-26-2005, 10:51 AM
Ok, thanks man. As of now I can almost turn the belt halfway. I'm going to try both tightening and loosening the belt a bit. I might wait until a damp day so I can tell if the high pitched noise goes away.
Old 08-26-2005, 11:14 AM
Senor Miembro
ecahatch's Avatar
if its whinning its too tight.
Old 08-26-2005, 12:18 PM
Awesome. Thanks for all the replies guys
Old 08-26-2005, 12:32 PM
FalkenSiR's Avatar
Wait, before you guys go
How would us guys with Power steering do it? Adjust it I mean. Take out PS pump bolts (2), move it out the way and then adjust? I just looked at it and you can't reach it.
Old 08-26-2005, 12:58 PM
struppi's Avatar
Yes, it can be too tight and you might not even notice. Mine was squealing too, I tightened it up and everything was fine for a few months until the compressor suddenly cracked from the tension. Most costly mistake I ever made.
WaryDriver
27
10-07-2015 08:42 PM
Fo-Do Fanatic
04-07-2010 03:59 AM
lude1888
06-06-2007 09:26 PM
drewbie
07-30-2004 08:19 PM
Jaybird20
06-07-2004 08:37 AM
Quick Reply: How do I tighten my A/C belt? (Pictures included)
