installed thermostat but heat is not very hot
i installed a new thermostat today and now i do have some heat. But it is as strong as it should be. anything else i could do?
Re: installed thermostat but heat is not very hot (drjay2022)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjay2022 »</TD></TR><TR><TD CLASS="quote">i installed a new thermostat today and now i do have some heat. But it is as strong as it should be. anything else i could do?</TD></TR></TABLE>
yo man check your heater core, the fan, and the cable for the door
a new thermostat wont make your heat hotter
Re: installed thermostat but heat is not very hot (CGags13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 »</TD></TR><TR><TD CLASS="quote">
a new thermostat wont make your heat hotter</TD></TR></TABLE>
it wont? not even if the old one was stuck open? of course it will.
did you bleed the air out of the system?
Re: installed thermostat but heat is not very hot (95DxSi-R2)
yes i am doing it with the car off, and when you say bleed it, where should i bleed it from
thanks, jay
thanks, jay
you have to burp the system
1. fill the coolant to the brim
2. start the car
3. bubbles should start forming in the coolant
4. the coolant level should drop, so add more coolant
5. It will smoke, its ok
6. just keep doing this until the coolant doesnt drop anymore
2. start the car
invisible
44
02-22-2008 01:33 PM
fridexter
11-20-2004 02:52 PM
dman81
08-04-2004 10:48 AM
