B16b transmission questions
i was just wondering if anyone knew the part number on a sc4 's differential...i want to go see if honda has some for sale but i need the part number off them because they dont know what im talking about when i say a civic type R...thanks
tye
tye
i have a b16a tranny, and i want a diff out of a ctr or itr, whichever diff. part number i can get because i want a LSD but dont got ther money for a sc4, and i dont want to buy a phantom grip or anything , i want the factory so i know it will stick with me. thanks
tye
tye
Re: (infumis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infumis »</TD></TR><TR><TD CLASS="quote">i have a b16a tranny, and i want a diff out of a ctr or itr, whichever diff. part number i can get because i want a LSD but dont got ther money for a sc4, and i dont want to buy a phantom grip or anything , i want the factory so i know it will stick with me. thanks
tye</TD></TR></TABLE>
If you have a b16a tranny you will also need to get the final drive. I thought you had a ctr tranny and wanted to replace the lsd. In your case, the final drive will not bolt onto a honda ctr or itr lsd so you need the final drive too. Total cost will not be cheap. You are better of buying a quaife for your tranny since it will work with your existing final drive.
still, i know what i need and i got the final drive, but i want a NEW factory built diff with factory lsd, so if anyone has the part number like the topic was asking it would help me alot thank you
tye
tye
Re: (honda 3300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda 3300 »</TD></TR><TR><TD CLASS="quote">your not gonna want to pay what they want </TD></TR></TABLE>
no ur not!
no ur not!
Re: (atomik speed)
b16 and ITR final drive is compatible, you can use a final drive from a b16 with an ITR lsd. you don't buy a new final drive when you get a quaife... same applies to all LSD.
Re: (fastrunner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner »</TD></TR><TR><TD CLASS="quote">b16 and ITR final drive is compatible, you can use a final drive from a b16 with an ITR lsd. you don't buy a new final drive when you get a quaife... same applies to all LSD.</TD></TR></TABLE>Try it.
The final drive ratio between both cars are the same, but the ring gear on the ITR/CTR is different from a B16A. The actual LSD unit is not compatible and will not bolt up to the other's ring gear.
And to the original poster, I got my OEM LSD off eBay from this guy:
http://cgi.ebay.com/ebaymotors...wItem
5,000 km later and no problems. Working normally. Highly recommended.
You do know that you will need the differential bearings from a 98-01 ITR and will need to check the clearances again right?
Re: (imports automotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imports automotive »</TD></TR><TR><TD CLASS="quote">hes right ^^^ is not compatible it doesn't bolt up</TD></TR></TABLE>
I already told this to the orignial poster and he is still interested in getting new oem stuff. He knows he needs diff and final drive.
civicdohc
11-21-2003 01:59 PM
