clutch master cylinder help
HT Order of Merit
Re: clutch master cylinder help (sol lovin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol lovin »</TD></TR><TR><TD CLASS="quote">tools needed:
socket, wrench
1. open your hood
2. stare at it for a while
3. do the work</TD></TR></TABLE>
lol, yea its pretty straight forward man. Unbolt it, and bolt the new one in. Bleed.
socket, wrench
1. open your hood
I am a (Trial User) Army
Re: (T-RO)
Re: (litterbox)
I just replaced a leaking clutch master cylinder a few weeks ago. Took me all of 1 hour and 15 minutes to swap and bleed hydraulics. Would have been an hour, but the clutch line pipe fitting to the cylinder was buggered up and would not accept the size wrench it was suppose to.
Disconnect hydraulic line (line pipe wrenches are the best tool)
Disconnect cyinder piston rod from pedal (inside car). 1 bolt
Remove two bolts to unmount the master cylinder in engine bay.
Reverse for install
Bleed hydraulics.
The best tip though is buy this: I actually bough mine for $18 at their store.
http://www.harborfreight.com/c...92474
A vacuum bleeder kit. WONDERFUL TOOL! I have the clutch hydraulics completely purges with dot 4 fluid and air free in a matter of 5 minutes, all by myself. Not need for someone to be stomping on the clutch pedal to pump fluid through hydraulics.
Reverse for install
Bleed hydraulics.
AndyD
02-03-2003 09:47 AM
