yes or no... simple question
I purchased the “red” silicone gasket maker from AutoZone a couple days ago for my transmission oil bolt… just a question, will this stuff work with an exhaust manifold as a gasket? It’s rated at 600F I think or was it Celsius. Not sure but can I use this instead of a gasket? this is an oem header/manifold by the way.
Darth ModerVader
Re: (unrefined7)
Assuming they're in good shape, you can reuse the one at the head and the one between the upper and lower half of the manifold, but I wouldn't recommend reusing the donut gasket at the collector.
Re: yes or no... simple question (x93coupex)
Better off just using the right exhaust gasket. It will save you trouble in the long run.
Re: (unrefined7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unrefined7 »</TD></TR><TR><TD CLASS="quote">can i reuse my old manifold gaskets?</TD></TR></TABLE>
If they are in good shape sure. I have done it before without problems and mine were in pretty good shape.
I have since then replaced it when I rebuilt the motor but the gaskets came with some stuff that I ordered. If you have to reuse as long as it is in good shape I would not worry about it.
TUR3Ovtec
06-14-2010 03:44 PM
