injectors
injectors
when i convert to obdI from ObdII do i need 0bdI injector clips? I dont think so, that would be only if i used obdI injectors, correct?
Re: injectors (tuck'd98)
what exactly are you converting? are you doin an engine swap. Send me some info. If you are doing an engine swap u can get the obd2 motor and trans but stay obd1 for east tuning.
You only need your injectors to match your injector clips. If you have an OBD1 injector wiring harness then you will need OBD1 injectors and like wise with OBD2. Either can be swapped though, but cheapest to alter injector clips. OBD1 injectors are more readily available though.
Re: injectors (BryanPendleton)
alright thanx. im in the stages of turboing my d and im upgrading injectors to 440cc and converting to obdI for tuning
