Will a 99-00 SiR/B16A2 header (for you US peeps, SI) fit on a GSR/B18C
As the title says...
I've heard that the B16A2 header will fit on a B18C (94-99 GSR). its this true or not?
cute little bastard
Re: Will a 99-00 SiR/B16A2 header (for you US peeps, SI) fit on a GSR/B18C (BubLBack33)
I'm pretty sure it bolts up to the head fine, but I'm not sure on the clearance with the bottom
Nope won't fit.
You can put a header from a B18C1 onto a B16A2, but you cannot put a B16A2 header onto a B18C.
The reason: B18C1 header is taller than the B16A2 header. Make sense to you now?
Re: (zclee.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zclee.com »</TD></TR><TR><TD CLASS="quote">be my guest if you want to try. i tried before and it didnt clear the oil pan.</TD></TR></TABLE>
are we talking about aftermarket or stock?
I was 100% sure both would bolt on properly without clearance issues but the GSR would hang lower.
My bad then, I was mis informed
Re: (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRMike »</TD></TR><TR><TD CLASS="quote">Nope won't fit.
The reason: B18C1 header is taller than the B16A2 header. Make sense to you now?</TD></TR></TABLE>
B16A2 header will not clear a B18C oil pan, I believe B18C blocks are slightly taller than a B16A2.
this would be an aftermarket header...
do you any of you guys know if the type-R header will directly bolt on to the stock EG cat?
Thx for your responses guys...
cute little bastard
Re: (BubLBack33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubLBack33 »</TD></TR><TR><TD CLASS="quote">this would be an aftermarket header...
Thx for your responses guys...</TD></TR></TABLE>
If the collector is 2.5", no
so what kind of header can i get that will directly bolt on to the GSR head and the stock EG cat? is there one out there or will i have to customize my hole exhaust system again?
Re: (BubLBack33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubLBack33 »</TD></TR><TR><TD CLASS="quote">so what kind of header can i get that will directly bolt on to the GSR head and the stock EG cat? is there one out there or will i have to customize my hole exhaust system again?</TD></TR></TABLE>
If a header that accomplished this exists I am not aware of it. Would have to be some kind of hybrid header. Why would you want to use the stock EG cat anyway?
Re: (zclee.com)
beat me to it...
beat me to it...
gulftiresinc
09-14-2004 03:26 AM
