final drive compatibility
* B A N N E D *
can the 3.25 final drive from a crx hf fit in a hydro ek cx tranny? I know the fd is lower and was thinking about it to conserve fuel.
Modified by cbmprelude at 6:12 PM 4/22/2006
* B A N N E D *
Re: (schardbody)
ohh ok thanks the website I had looked at published it as the 3.7 Is there any problem with upgraded to say the 4.2 in the ex? Will there be space issues or will I have to ground down the inside of the tranny?
* B A N N E D *
Re: (cbmprelude)
Bense's thread
https://honda-tech.com/zerothread?id=1593351
claims my cx has a 3.7 with the eg has a 3.25
Go Tigers!
Re: (cbmprelude)
67/18 when I counted my 96 cx final drive
cx shares the same transmission as the same year vtec-e model.
92-95 cx / vx is the same
96-00 cx / hx is the same
Go Tigers!
Re: (Bense)
3.25 is found in some crx hf's But it's pointless to try to get that to work in a hydro case. Because by the time that you do all that, you could have bought either a vx/cx final drive from either bone or me for very cheap.
I think I have two of these things. Wait, I am getting a vx tranny tonight for free, so I have three of these things.
Not worth putting a 3.25 in any transmission, because it will be easier to find one of those vx boat anchors that honda calls a transmission.
Because of the confusion with cx/vx and cx/hx transmissions I always try to refer to the 92-95 cx as a vx transmission. While refering to a 96-00 cx as a hx transmission.
92-95 vx gears are far apart from each other with the 3.25 final drive
remember, these cars had 13s on them. And didn't make any power past 4k rpm.
96-00 hx gears are the same as 96-00 dx gears, but with the 3.7222 final drive instead of a 4.058
vx = (65/20) 3.25
hx = (67/18) 3.722222222222222222222222222222222222222222222222 2222222222222222222
dx = (69/17) 4.0588235294117647058823529411765
ex = (68/16) 4.25
vx = (65/20) 3.25
ex = (68/16) 4.25
* B A N N E D *
Re: (schardbody)
I just purchased a cx eg tranny from a great fellow ht-er. I will bolt it to my d16y7 in the fall in see how my fuel economy reacts
Go Tigers!
Re: (cbmprelude)
the difference is like 200rpm at 80mph in 5th gear between the final drives. Not enough to make a difference. The only real advantage is if you had a hx or vx engine with the lean burn and say you were doing LOTS of traveling on flat ground at a speed that was say 100rpm higher than where vtec engages.
00-ITR-373
03-30-2002 05:47 AM
