96-98 EK civic square Fog light install... HELP.
hey, im having trouble figuring out how to install these fog lights onto a 96 bumper.
i know how to wire it up, just cant seem to figure out how to fit it up, i dont want to start cutting it, as i have searched other old topics, and they say you dont cut, etc? but doesnt tell me much more,
there has been alot of guys who have fitted these, so go on throw me some help
as far as i know, all the OEM brackets etc are complete with the foglight unit itself. just need some instructions on fitting to bumper. were to start etc.
sorted... that link above helped alot, just follow the instructions on how and where to cut the grill.
basically the square light brackets bolts up to the pre-mould holes, and then you bolt the light unit to the bracket,
then wire them up.
then wire them up.
Re: (blazed_racer)
the ground wire is too small...you might run another ground b/c the orignal ground will burn up...happened to mine 3 weeks after i got them. just my 2 cents...
Re: (EJ8kid)
I never had a problem with the ground. I just ran it to the ground where the valve cover ground is.
The circle foglights have the same cut out so it will work perfectly.... Square ones look better IMO
Re: (EJ8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8kid »</TD></TR><TR><TD CLASS="quote">the ground wire is too small...you might run another ground b/c the orignal ground will burn up...happened to mine 3 weeks after i got them. just my 2 cents...</TD></TR></TABLE>
oh yeap. cheers for that,
DeDonDeRosa
02-24-2007 07:22 AM
