Throwing code 91 help
exactly what the title sez. I'm just trying to figure out why my car is throwing it and what normally causes it. Some details that might help:
I have a '97 JDM gsr b18c swapped into my '97 Honda Civic Ex. I have the evap canister from a '98 Civic because mine wouldn't work with the GSR wiring
I remember just before I sent out the engine wiring harness that it had a O2 sensor simulator.
My cat may be suffering from a little bit of blockage.
Thanks!
Thanks!
what ecu are you using? there is a number of things that casue that code. could be anything fro ma vacum leak to a bad evap purge soelniod , fuel tank pressure sensor and the list goes on. a jdm ecu wont look for a fuel tank pressure sensor tho
There's your problem. Fuel tank pressure sensor. This is one way to fix it. It does work, I've done it. Just follow directions on first page by John Conner. The other option is a jdm ecu. Your choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97mini-me »</TD></TR><TR><TD CLASS="quote"> Just follow directions on first page by John Conner. </TD></TR></TABLE>
May I have the link please?
Sorry. I thought I pasted it in the last post. Here it is. Good luck.https://honda-tech.com/zerothread?id=767817
red-si-eg..
Feb 26, 2008 06:21 AM
