NEED HELP!!!: Removing aftermarket steering wheel****** Pics
I need some help with removing my aftermarket steering wheel. I need to know how to get this sliverish metal thing off. I tried pulling it off and i looked for some screws that might be holding it in place but nothing... here are some pics
NASIOC.com
Re: (AirForceB16)
Cut it off... lol jk... what i did with mine is just removed nut that holds the hub and put the steering wheel back on and just put some rope around it and pulled the ****** out... also wd-40 helps
Re: (Otherguy)
i used a bar and hit it off. bad idea... then the second time i did it.. i had a momo hub.. so it was different.. but i put a bar through the holes in it.. and yanked... almost smashed my head.. that was another bad idea.
just rent the tool at autozone
As long as I dont have to take out any more Metal Gears
Re: (delslowhonda)
After u take off the center nut, bolt the wheel back on it. Then pull with the steering wheel while a buddy taps the hub with a mallet
Re: (rukawa1one)
thanx guys, great advice, i might try the puller if i get a chance or one of the other more ghetto ways...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight »</TD></TR><TR><TD CLASS="quote">and yanked... almost smashed my head.. that was another bad idea.
except this one
except this one
Re: (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight »</TD></TR><TR><TD CLASS="quote">i used a bar and hit it off. bad idea... then the second time i did it.. i had a momo hub.. so it was different.. but i put a bar through the holes in it.. and yanked... almost smashed my head.. that was another bad idea.
hahhahahaha, you made my day.
1 Post
Re: (jacka$$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacka$$ »</TD></TR><TR><TD CLASS="quote">Put the wheel back on and pull till it hurts. Thats when it will come loose and get you in the teeth. </TD></TR></TABLE>
this will work. Also wiggle it up down side side
b18_crx
06-19-2006 09:19 AM
Sijray21
02-28-2006 08:33 AM
