TRanny removal?
TRanny removal?
We are going to remove my brother's tranny this weekend. It is a 00 civic si. Anybody got links of pictures and directions of how to remove it. Much appreciated.
Re: TRanny removal? (Heretic:Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com »</TD></TR><TR><TD CLASS="quote">Type of engine mounts used would matter was well.
Procedure for the most part
Since you have done it before, will not speak of axles or bolts between block/tranny since you know of them already.....
Remove half shaft and jack shaft
Loosen back bracket from mount on rear xmember.
Remove 2 bolts to tranny, 1 bolt to block.
Most of the time, for extra clearance, you should remove the radius rod (arm between lower suspension and front xmember (1 bolt in front, 2 bolts in rear -in that order is easiest)
Remove bolt to chassis from top tranny mount.
Normally went putting it back in. Have the starter off and that top mount off until you get the tranny up on the motor. Make sure not to smash up any wires as they tend to fall right down in your way (o2 sensor wire is normally the worst)</TD></TR></TABLE>
Re: TRanny removal? (TEGGRY)
not to sound mean but buy the repair manual!
that thing is great
i never worked on my car alone, i bought the repair manual and replaced the clutch in my civic, that was the first mod besides intake i did!
the manual will thell you how to remove it but it wont tell you the lil secrets that youll have to firgure out along the way!
good luck and dont give up!
that thing is great
coot_er
12-24-2005 03:46 AM
