Need help chosing a motor!!!!!
Ok, So I drive a 98' hx coupe, just shot a rod out the bottom end, and now I need a swap. I am on a 5k budget and I need to know whether to get a jdm h22, or go with a gen 2 b16. Help please.
Re: Need help chosing a motor!!!!! (gossafied)
if i was you i would go b18 but a b16 is a good starting platform get whatever u want idk
With a 5k budget, decide first what you want to do and then RESEARCH the best way to do it.
This topic is going to be closed just so you know.
All I'm going to say is you don't have to use the entire 5k budget on the motor swap alone.
You can spend say, 3100 on swap and another 2k either on suspension or on building the motor. You could even spend 2500 on the swap and 2000 on suspension/bolt ons and another 500 on aesthetics like gauges, interior and stuff.
Whatever sounds most appealing to you. Just make sure that you give yourself a little monetary slack for the parts you're going to NEED in order to get the car running. (ex. Tune-up parts, tie-rod end, misc. sensors, etc.)
NASIOC.com
Re: (dangle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dangle »</TD></TR><TR><TD CLASS="quote">Whatever sounds most appealing to you. Just make sure that you give yourself a little monetary slack for the parts you're going to NEED in order to get the car running. (ex. Tune-up parts, tie-rod end, misc. sensors, etc.)</TD></TR></TABLE>
yeah dont be like me... Tried to swap a d16y8 which is OBD2a into my 92 civic which is OBD1... We had to run around looking for a new intake mani... we found a 93 si after 3 days of my car being down.. Also.. and I had to peg my dizzy.. which sucked cause it fell off once while i was driving
Re: Need help chosing a motor!!!!! (Essenar83)
I'm with (Essenar83) choose what you want and can afford. You can ask 30 people and they will give you 30 different routes to go. good luck on your project and keep us posted on what you went with. My opinion is.....as long as it's Honda you made the right choice.
NASIOC.com
Re: Need help chosing a motor!!!!! (orangerex04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangerex04 »</TD></TR><TR><TD CLASS="quote">id get a spoon motor overnighted from japan with a motec system exh </TD></TR></TABLE>
what a great waste of money...
Re: Need help chosing a motor!!!!! (Otherguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy »</TD></TR><TR><TD CLASS="quote">what a great waste of money...</TD></TR></TABLE>
Get it....Get it.....
Re: Need help chosing a motor!!!!! (No_Beer-No_Honda)
ls/v or b20/v will be cheapest and will provide most power and you can get either swapped with all the **** you need axles ecu harness etc... for less than 5k or i would say a b18c1 dont waste your money on a b16a h22a is also a cheap route. b20/v FTW
Re: Need help chosing a motor!!!!! (eg4metodrive)
what a great waste of money...</TD></TR></TABLE> I sincerely hope that u are kidding and got the joke. ANYWAY i would get a b16a and swap in a final drive. but seriously dude use the search button
Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business »</TD></TR><TR><TD CLASS="quote">$5k?
b18c1, mounts, cams, cam gears, a good header and a tune.</TD></TR></TABLE>
you will need a management for that tune and a hondata will do
Re: (No_Beer-No_Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Beer-No_Honda »</TD></TR><TR><TD CLASS="quote">
get what you want, not what Honda-Tech wants </TD></TR></TABLE>
