stock z6 headgasket
stock z6 headgasket
are any of you sohc guys making decent power numbers on a stock metal Z6 gasket???
cometic is metal multilayer and so is the stock one.... i figure it should be safe??
any opinions
forced induction by the way
any opinions
Re: stock z6 headgasket (claytonsmith)
Cometic is the same **** as a stock MLS gasket.
Don't get ripped off by cometic. The only time I would buy a cometic HG is if I need to raise the compression without changing pistons and such.
Just remember every time you blow out a HG you're stuck paying $100 for a new HG.
this is totally uneducated so someone please correct me if i'm wrong, but i was always under the impression that the z6 gasket was not metal, but the y8 was and fit the z6. im pretty sure the y8 gasket is much cheaper as well.
Re: stock z6 headgasket (wudini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wudini »</TD></TR><TR><TD CLASS="quote">this is totally uneducated so someone please correct me if i'm wrong, but i was always under the impression that the z6 gasket was not metal, but the y8 was and fit the z6. im pretty sure the y8 gasket is much cheaper as well.</TD></TR></TABLE>
The Z6 HG is steel. The Y8 and the Z6 are the same HG. Don't be duped into spending $80 on a Z6 when the Y8 cost half as much and is the same.
Re: stock z6 headgasket (F20Cteg)
the z6 is steel however the aftermarket companies do sell a cheaper "crush" style gasket. JUNK
ill be running a felpro MLS headgaset on my LS setup.... ive always used them. never had problems.
Re: stock z6 headgasket (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">the z6 is steel however the aftermarket companies do sell a cheaper "crush" style gasket. JUNK
ill be running a felpro MLS headgaset on my LS setup.... ive always used them. never had problems.</TD></TR></TABLE>
Crush style?
How do you think any gasket works?
Crush style?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg »</TD></TR><TR><TD CLASS="quote">
Crush style?
the cheap headgaskets that are in form of the aftermarket exhaust manifold gaskets. i thought that i would be able to get my point across without someone bringing that up, but i guess i was wrong. i was talking about the one piece gaskets
Crush style?
the cheap headgaskets that are in form of the aftermarket exhaust manifold gaskets. i thought that i would be able to get my point across without someone bringing that up, but i guess i was wrong. i was talking about the one piece gaskets</TD></TR></TABLE>
Those are referred to as composite gaskets.
thank you sir
im not too familiar with them as i have never used them
thank you sir
whoa whoa whoa... ok
so
z6 and y8 gaskets are both MLS... i was aware of that i think
but i thought one was a 2 layer and one was a 3 layer??
and why is the y8 gasket so much cheaper than a z6 one?
so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by claytonsmith »</TD></TR><TR><TD CLASS="quote">whoa whoa whoa... ok
and why is the y8 gasket so much cheaper than a z6 one?</TD></TR></TABLE>
Supposedly you can order a two layer gasket, but I have never been able to.
Every single part for a Y8/Y7 is cheaper. Most stuff is half the cost of the old motors. Also, every SOHC 96-00 civic used the same HG. DX, EX, HX, etc, they are all the same MLS HG.
roycivic92
01-10-2005 06:14 AM
fastcrxsi90
05-01-2003 06:48 AM
