opinions on nitrous
Re: opinions on nitrous (f20b eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f20b eg »</TD></TR><TR><TD CLASS="quote">i run 60hp and i have been running for long time that does not mean it is good
but i have got it tuned for nos
cheapest hp </TD></TR></TABLE>
do u have a wet or dry setup .. n how many miles are on ur motor
Re: opinions on nitrous (cleanej2)
wet better than dry b/c a wet kit also injectes extra fuel with another injector that comes with the kit. whereas a dry kit depends of the stock fuel injectors to make up the difference. wet has less of a chance to cause detonation on your motor, also getting your car tuned for nitrous will help with the reliablility factor.
the best setup is a direct port kit
I'm building a D15B with a ZC block. All OEM parts, no rebuild. I'm planning on buying a Zex wet kit with a ~50 shot.
I've got no worries about cooking my motor. Just install the kit properly and use a realistic jet setting and you should be fine. I'm assuming you're only going to use it occationally.
The only reason ppl think Nitrous is dangerous is because they dont know what there doing and spray over and over thinking there motor is not getting hot since the dummy gauge doesn't say so. When I used Nitrous I hooked up a EGT sensor so I could see my exhaust temps. I never had any problems on a stock motor.
foowitdaredek
22
04-30-2007 12:43 PM
CRXstress
11
06-01-2005 08:20 AM
StreetRacnGsR
24
06-06-2003 09:11 AM
