H22 axle problem
H22 axle problem
Well yesterday I decided to run my car at the track. First time down I pulled a 14.3 at 95 mph with a 2.2 60 foot, just babying it. So On my next run I really heated up the tires (Nitto Neo-Gen) and tried to launch, well lets just say it stopped moving. I'm pretty sure i broke an axle on the passenger side, since when we were pushing it, i could hear it clicking. My question iswhat axle do I need then? Ive searched but I dont understand how to make 90-93 Integra Axle use a prelude/accord inner CV joint in order for the axle to lock into the transmission. The inner spline shaft is slightly longer for the prelude/accord than the integra, 90-93 Integra shaft and outer CV will work with the prelude inner.
So my question is, how do I ask for one of these at an automotive place?...Im on a tight budget now, so I was looking for some feedback...thanks guys
Re: H22 axle problem (jpnucrx)
its very easy...
just take a 90-93 teg axle and a prelude axle then swap the inner from the lude to the teg. its very simple. all you need is grease and a new axle clamp.
Re: H22 axle problem (USDMej1)
ok what you need is inner cv axel piece of accord 5 speed f22b on the passanger side and do just like usdmeji indicated.i know the passenger side of the inner axel which goes into transmission integra one will not lock so go to the junk yard and pick up the accord end piece i paid 5 dollars.
Re: H22 axle problem (f20b eg)
ok...what year accord , with a f22b? Then buy a 90-93 teg axle and put the inner accord end on so that it pops into trans?
Accord inner Teg Outer
go to any place that sells a jdm accord engines ask them to sell the end cv joints because before the send engines out from japan they cut the axels the end pieces are still on the engine.get any 94 and on accord
So it has to be from a JDM accord....or any accord 5 speed?...Damn...this might be harder than i thought to maintain. Any other options work...i dont really know of any place around here that might sell motors that could help me.
call eric japan in dallas texas he will charge you $5.00 and will ship it for you trust me i kknow integra axel does not lock even have the pro shop around did not know i figgured it out by experimenting .i think he will charge you 15.dollars shipped to your door
whats the number there? Just ask him for the JDM Accord 5 speed Pass side Innerr axle?..Thanks for all the help man..then just get a teg axle and put them together...
Eric Japan Engines, Inc
121 Commercial St, Garland, TX, United States
Phone: (972) 272-4186
ask for jimmy
ther you go get that mated to teg axel no tranny fluid leaks at all
pm me you need more help
ask for jimmy
He wasnt there when I called...Should I just try the Junkyard for an f22 Accord axle...will that be easier maybe...I really need to get this car running...Im losing time from work...
