Car making wierd noise!!
Well heres the case, i was driving today and all of a sudden there was like a grinding noise coming from the front. It doesnt make the noise when i step on the brakes only when my car is moving. Even when the car is off or in neutral it makes the noise. I notice its coming somewhere from the wheels. Does anyone know what the problem might be and how i might get rid of it?
Re: Car making wierd noise!! (vi3tromanc3r)
Check the inner fender wheel lining... A tab/ screw could have come out! If thats the problem, it will hit/ rub against the tire and make a nasty noise!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3tromanc3r »</TD></TR><TR><TD CLASS="quote">Well heres the case, i was driving today and all of a sudden there was like a grinding noise coming from the front. It doesnt make the noise when i step on the brakes only when my car is moving. Even when the car is off or in neutral it makes the noise. I notice its coming somewhere from the wheels. Does anyone know what the problem might be and how i might get rid of it? </TD></TR></TABLE>
can you describe the "noise" deeply or not?
There can be about 10,000 "noises" coming from the front end only when not braking.
hm iono how to describe the noise, buts its not the fender. its like when my car is rolling and im not gasing it, it makes a wierd grinding noise. im not to clear on how im going to make the noise on this. but im sure its from the wheel area.
Re: (vi3tromanc3r)
check your car's break pads, Normally if your at a slow roll and hear grinding it mean's there's no more breaks and its to the bare pad. my mom has this problem right now actully and we found out what it was.
break pads.. Sometimes there can be rocks that cut up behind the dust cover.. or maybe your hearing things, im kiding,but check behind the dust cover of the breaks.
Re: (POE)
as above have said, brake pads...
fender liners don't stop scraping when you hit the brakes... belts don't make any noise if the engine isn't running, nor do they grind for that matter
Re: (POE)
your brake pads need to be replaced, and since its making a grinding noise...you probably should go get a new set of rotors too.
Re: (ek9bmxer)
nvm found out wut it was, just somehow my wheel was coming loose. and 3 out of the 4 lugnuts were loose. iono how they started loosening themselves but yea i tighten them and now no more sound.
