can neone giveme addvice!!!!!!!!!!!!!!!!
what every one i was just wondering if i changed my flywheel to after market and leaft my clutch to oem would i notice a differance or should i just leave my stock flyywheel thanks much if you can help
Re: can neone giveme addvice!!!!!!!!!!!!!!!! (civic99white)
why change the flywheel and not do the clutch one time while your in there? you will feel a slight difference since it will rev up a little faster. but there is no telling how good your stock clutch will grip. i just did mines, i got a stage 1 clutch and i lightened my stock flywheel, and it feels alot better. im chirping third now in the si.
Re: can neone giveme addvice!!!!!!!!!!!!!!!! (Mr.EM1_EK)
realize that when you go to a real light flywheel, that your are taking away the inertia that the crank uses to bring the piston and rod out of TDC on the power stroke, going too light will stress the rods and piston more than I am willing to chance. 14lbs is the lightest I will go.
There is a reason they weigh 18lbs.....
I had a stage 1 clutch with the 7.5 lb fly wheel for some while now and we recently took my motor apart my rods and pistons are in excellent condition and i did beat the hell out of the car on track
i can get a third gear chirp into third on stock flywheel and stage 1 exedy. All a lightened flywheel does is rev quicker and the HP gain is minimal. I am against it because you lode all your jump off the line and in a torqueless honda that can be a downfall...gets to the power making rpm's fater tho. its a money vs. gain type thing and unless you race alot then its kinda a waste...i think.
Re: can neone giveme addvice!!!!!!!!!!!!!!!! (FastLife617)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">realize that when you go to a real light flywheel, that your are taking away the inertia that the crank uses to bring the piston and rod out of TDC on the power stroke, going too light will stress the rods and piston more than I am willing to chance. 14lbs is the lightest I will go.
There is a reason they weigh 18lbs.....</TD></TR></TABLE>
Its not gonna put insane amounts of stress on it but if your making any kind of power, your looking for trouble. What do your bearings look like? and why did you rip it apart?
Re: can neone giveme addvice!!!!!!!!!!!!!!!! (slowcivic2k)
I just got bored with my motor i want a new set up plus my friend ended up giving me his parts that he was about to use for his motor build but his car got stolen and of course im not going to refuse a offer on free stuff and My bearings looked fine
Canadian_EF
Transmission & Drivetrain
03-24-2011 06:47 PM
colbynorwood
03-16-2011 06:42 PM
treborpaul
04-20-2009 05:08 AM
SLEEPER775
08-24-2008 10:21 AM
tweekerz
07-28-2006 07:43 PM
