Putting an integra b16a/turbo into a 93 civic/1.5, I need help, my first honda/swap!!!
my first post. lets get to it.
what i have:
* a perfect 93 civic EX with a jdm 1.5 sohc vtec and a turbo with a lot of goodies. the engine is blown.
* a 1990 integra gs with an SIR b16a first gen. the car is junk, the engine runs great. it has a cable trans, and a PR3 ecu. it looks like it has been swapped.
* no knowledge or experience with hondas.
my first question:
ive read its best to set the car up OBD1, and you can do that with a PR3 ecu. is it best to set the civic up for OBD1? isnt the integra PR3 obd0?
second:
the b16, the b16 engine harness, the b16 distributor, the b16 ecu all work. can i install them in the civic, then plug into the civic car harness? meaning is it all swapable?
im very serious about this. i have money, time, and every tool imaginable at my disposal, as well as a machine shop and a junkyard. unfortunately no b series hydraulic transmissions though.
help out a new honda owner!!
what i have:
my first question:
second:
no comments?
i have an update: i pulled the ecu out of the civic, and its a P28. ive read that this is OBD1, and is recommended for the swap. can i use it to run the integra engine?
Re: Putting an integra b16a/turbo into a 93 civic/1.5, I need help, my first honda/swap!!! (b dub)
my first question:
(you said if you have a p28 stick with that)
second:
(if not just get a clip or ecu harness coverson for your ODB)
second:
Re: Putting an integra b16a/turbo into a 93 civic/1.5, I need help, my first honda/swap!!! (ek4h)
"you said you have a p28, stick with that."
will it start the car right away, or will it need to chipped, modified, etc? and if so, where do i send it to?
"if not just get a clip or ecu harness coverson for your ODB."
isnt the PR3 Obd0 and the P28 OBD1? which one is recommended?
Re: (b dub)
Convert the motor to obd1.
Get a hydro tranny unless you want to do a complete hydro to cable conversion in which case involves the use of Hasport mount.
i dont mean to sound like the annoying stepson, but why is 0BD1 preferred? because of the turbo, the compatability, the emissions, the efficiency, combo of these?
considering everything i have to get for OBD1, and the fact everything OBD0 on the integra works fine, it might be cheaper to keep it OBD0.
whats the price of a harness, and where to get one?
fiktion91
06-07-2012 02:39 PM
