What flywheel
What flywheel
Rocking a jdm b18c5 motor and going with a action 6puc clutch but want to upgrade the flywheel while its off anyone recomend a particular brand i was going to use a 7.5lb fidanza or what not cause they are cheap but cheap is not allways best any input at all gets a thanks
Ek Forever y0!
Re: What flywheel (ekBlackHatch)
Check out gripforce clutches on ebay, he has the best pricing on fidanza flywheels.
I got my OE clutch and 8lb fidanza for my D-series for $205 shipped.
Re: What flywheel (doood)
yeah for the price its offered i think its great to the op i would check out that gripfroce clutches on ebay that EK forever guy mentioned that's a really good deal
Re: What flywheel (ek forever guy)
well i allready got the clutch i want to get figured out action 6puck just needed a nice flywheel weither it was a j's toda or fidanza thanks for some feedback any other flywheels you guys use or recomend
Re: What flywheel (fridaytech)
7.5lbs is too light, i would try to stay in the 12-14lb range, there is a reason flywheels weigh 18 lbs..... and it isn't to reduce performance....
From what I've heard and experienced, The lighter of the 2 flywheels ( the 7.5 ) sacrifices some of your launch speed, but top end gains are better. The mid-range flywheel ( 12-14lb ) is good for all around, strret and strip. I had a 12 lb on my old SH and was very pleased with it, and it was a Fidanza and yes, they are cheap in price, but not quality. IMO
Re: (ekBlackHatch)
the problem with aluminum lywheels is that they tend to be multi-piece units while chromoly units are one piece. look through the archives an you will find stories of alumium flywheels(even fidanza) "exploding" during misshifts. find a good chromoly lywheel such as ACT and exedy(only 2 I can think of off the top of my head).
I had an exedy in my b16a hatch (weighing in at aroud 9 lbs). I will tell you though, anything lighter than 12 lbs will take some serious getting used too (plan on looking like a 1st time driver for the entire first day at least)
Ek Forever y0!
Re: (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man »</TD></TR><TR><TD CLASS="quote">Driveability issues with a lightweight clutch is a complete myth, the lighter it is the easier it is to drive.</TD></TR></TABLE>
I agree, you just have to get used to it. I can't even tell when I shift or engage from a stop anymore.
Re: (ek forever guy)
The ACT streetlite is an awesome cheap and well made flywheel. You could buy another one when it comes time to change your clutch they are pretty cheap.
Re: (ED9man)
Bullshit, give me a solid explanation then as to why they weigh 18lbs in the first place, if its such a good thing, then why doesn't the factory issue 7lb slabs instead of 18lbs, thats a huge savings in weight and money.
The rod/piston assembly relies on the inertial mass of the flywheel to bring the rod/piston assembly out of TDC, so that the event stroke does not have to work as hard to push the rod/pistons assembly downwards, essentially all you are doing is making the combustion event have to force the piston downward, exerting more stress on them to make the same power, in order to turn the same speed.
Need I also mention that I4 engines are inherently out of balance by design, and an extremely light flywheel would only worsen this fact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">fidanza is good stuff</TD></TR></TABLE>
Re: What flywheel (Kareha)
Quick question, if you are deciding to updgrade to lighter flywheel, would you also have to look for a better aftermarket clutch, or would the oem clutch be good enough to take full advantage of the new flywheel?
And just to make sure, aluminim flywheels are more geared to racing, while steel are better suited for daily drivers correct?
