engine wont run right
B20 vtec engine wont run right
i have a B20vtec engine and it turns on but when i give it gas it it will only go to 3000rpm. and it wont go higher it just bogs. could it be my ecu not feeding the fuel right to the engine?
Modified by EGKREW at 9:23 PM 9/9/2007
Re: engine wont run right (EGKREW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">are u using right ecu? do u have any CEL ?</TD></TR></TABLE>
its a p28 ya pmd you
Re: (Kegan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kegan »</TD></TR><TR><TD CLASS="quote">Your ECU is in safe mode. Check your distributor and make sure everything is straight with it. Are you throwing any CELs?</TD></TR></TABLE>
+1
+1
Re: (Kegan)
ya everthing is straight with the dizzy. it is wired up right.i just bought it from ylm.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Is the check engine light on and, if so, what is the code?</TD></TR></TABLE>
ya the cheak engine is on!. what code?
Re: (91hybridDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hybridDX »</TD></TR><TR><TD CLASS="quote">Lookie here!
https://honda-tech.com/zerothread/1901557</TD></TR></TABLE>
checking
checking
Re: (EGKREW)
i get 6 short ones
i get 6 short ones
Re: (deerman2701)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deerman2701 »</TD></TR><TR><TD CLASS="quote">Check the ect?</TD></TR></TABLE>
that one thing will make the hole car not run right????
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">The coolant temperature sensor being fucked up can ruin all kinds of things, including the fuel tables and timing.</TD></TR></TABLE>
so how can i fix that?
Unceasing Measure
Re: (EGKREW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGKREW »</TD></TR><TR><TD CLASS="quote">
so how can i fix that?</TD></TR></TABLE>
...replace the sensor
Re: (Archidictus)
...replace the sensor </TD></TR></TABLE>
so all i do it cut a splice? that is the one under the vtec silonid. the grey on right not the white one
Modified by EGKREW at 12:46 PM 9/10/2007
Cool Cool Island Breezes. BOY-EE
Re: B20 vtec engine wont run right (EGKREW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGKREW »</TD></TR><TR><TD CLASS="quote">i have a B20vtec engine and it turns on but when i give it gas it it will only go to 3000rpm. and it wont go higher it just bogs. could it be my ecu not feeding the fuel right to the engine?
Modified by EGKREW at 9:23 PM 9/9/2007</TD></TR></TABLE>
make sure that the VTEC and CTS plugs arent interchanged. Black plug = CTS
Green plug = VTEC.
Green plug = VTEC.
Re: (EGKREW)
Modified by EGKREW at 12:46 PM 9/10/2007</TD></TR></TABLE>
no. replacing the sensor means unscrewing the sensor from the head and putting in a new one. I think it's a 19mm socket?? 21?? ah whatever.
Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
no. replacing the sensor means unscrewing the sensor from the head and putting in a new one. I think it's a 19mm socket?? 21?? ah whatever. </TD></TR></TABLE>
o ok thanks
o ok thanks
Re: (EGKREW)
my friends car had that problem yesterday. since his ecu is out in the open someone must of made one of the connections to the ecu come out a little because after we plugged it in tight it worked perfectly fine. maybe thats not the problem but it wont hurt to check
gl fixing ur car
gl fixing ur car
Re: B20 vtec engine wont run right (EjGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EjGirl »</TD></TR><TR><TD CLASS="quote">my friends car had that problem yesterday. since his ecu is out in the open someone must of made one of the connections to the ecu come out a little because after we plugged it in tight it worked perfectly fine. maybe thats not the problem but it wont hurt to check
gl fixing ur car</TD></TR></TABLE>
thanks for the advice but it is plunged in perfect.
