99-00 si rear disc conversion questions!
Cool Cool Island Breezes. BOY-EE
Re: (polything)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polything »</TD></TR><TR><TD CLASS="quote">you need 40/40 proportional valve from 4 disc brakes car like SI or integ.</TD></TR></TABLE>
you dont NEED IT. you just should have it for proper brake proportioning. The SI valve is really funky. I'm not sure which other cars take that valve. The older GSR valves also look weird. I'm not sure which valve you would need. I guess you could bend your lines to fit...but they may not bend like that or they may break.
Re: 99-00 si rear disc conversion questions! (94eghatchcx)
u will also need the e-brake cables from an si hatch, if u dont have them already btw the brakes will feel fine w/o a new prop valve
Re: 99-00 si rear disc conversion questions! (SoCal B18b 4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal B18b 4dr »</TD></TR><TR><TD CLASS="quote">u will also need the e-brake cables from an si hatch, if u dont have them already btw the brakes will feel fine w/o a new prop valve </TD></TR></TABLE>
they will feel fine, but they wont be affective. the correct prop valve puts a little more emphasis on the rear brakes. This will make sure youre using all 4 brakes more effectively. The stock prop valve will use the front brakes too much.
