Need some help with vibration...
whats up guys,
need to see if any of you can help with some problems im having with my 93 eg with B16a2 swap. since the swap ive been having a pretty bad vibration from the front end upon acceleration. if i were to take off from a dead stop it will shake very little but if im already cruising at about 50mph or so and i were to just give it gas in the same gear it will shake the dash off the car. so bad that the passenger window looks like it about to break. ive replaced all torque mounts, 2 front and 1 rear. ive changed my tie rods. the only thing left is my upper engine mounts or my axles are bent. if any one can point me in the right direction it would be greatly appreciated....
GO GIANTS!
Re: Need some help with vibration... (SiNiStER95)
Wow thats sounds pretty bad. At first I was thinking the torque mounts but you said you changed them. What about your clutch and flywheel?
Re: Need some help with vibration... (HondamanXxX)
when i bought the swap the motor already had a clutchmasters clutch in it... its got a really odd engagement and its got some small grinds. i dont mind replacing the tranny or anything else. i just need to change the right thing and have it solved. otherwise im going to give up and sell the thing.
id start with axles and go from there. a lot easier and cheaper. start easy and cheap and go up from there
Re: Need some help with vibration... (jonathan13)
i think i may just do that since there like 70 ea. wont hurt as bad as buying a new tranny or swapping the wheel bearings. ive heard it all. but i just dont know which way to attempt to solve this problem. i guess im the 1st to have this type of scenario
Any results on what you found to be the problem?
I have a 93 accord that vibrates and makes a violent thumping sound, sporadically, from the front end when I accelerate; it seems to do it worse after turning to the left sharply.
globy123
56
09-16-2018 05:53 AM
jeremiah963
05-19-2008 10:00 PM
vti444
11-14-2005 02:19 PM
