EK drum to disk brake conversion
Old 02-18-2009, 06:04 PM
royalrebel's Avatar
Default EK drum to disk brake conversion
So the time has come to get rid of those POS drum brakes on my 00ek. It seems so hard to find em on H-T and if i do come across one its already been sold. So anybody know where to get em?? and i want the brake lines, ebrake cable, the complete thing. thanks all help is appreciated
Old 02-18-2009, 06:08 PM
turbojdmhatch's Avatar
Default Re: EK drum to disk brake conversion
lets see...there is a for sale forum here...and a brake forum on here
Old 02-18-2009, 06:09 PM
Jas9848's Avatar
junkyard from an integra and pick up some si e-brake cables
Old 02-18-2009, 06:23 PM
cracker1252's Avatar
im doing the same thing. i was told look for either old teg or si rears, then you can buy a new cable from honda for some $. im sure there are many other ways also. YET so far that i have been told, only si or integra rears will work without making your own bracket.
(there is a guy on here that makes super eazy conversion brackets and sells them, ill search for it again. but try yourself also...)
Old 02-18-2009, 06:29 PM
royalrebel's Avatar
True there is.
But i dont have the time to be on h-t all day and wait for somebody to sell their brakes.
by the time i get on h-t...unfortunately they're gone
veightkiller's Avatar
check out your local junkyard should be alot of them. goodluck!
Old 02-18-2009, 07:43 PM
dj theoretic's Avatar
not looking hard enough... www.Hmotorsonline.com
$150
Old 02-18-2009, 08:23 PM
Jimster480's Avatar
u can get them on ebay alot of the time. Or craigslist. People are always parting out cars somewhere
Old 02-18-2009, 09:04 PM
JHP
JHP's Avatar
scarebird.
he sells them on ebay. here is the write up.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/96-00-civic-scarebird-brake-conversion-write-up-2251647/
Old 02-18-2009, 09:31 PM
Originally Posted by JHP
scarebird.
https://honda-tech.com/forums/showthread.php?t=2251647
thank you very much. i contacted him through ebay. hope he still can come up with them...
ALSO>>>> http://www.scarebird.com/index.php?id=22
Old 02-18-2009, 09:35 PM
xxblazexx's Avatar
fastbrakes makes a drum-disc conversion for 88-00 civics and has a front big brake package if you are interested in that
Old 02-18-2009, 09:57 PM
Redbone's Avatar
or u can take the whole rear setup from an del sol or an 99-00 si but use new si brake lines and e-brake cables for both of those setups. If you use the teg ones u need teg rear brake lines and si e-brake cables.
Old 02-18-2009, 10:01 PM
royalrebel's Avatar
would i be able to use the rear setup of a 91 integra??
Old 02-18-2009, 11:00 PM
ffa710's Avatar
Would i be able to use the rear setup off any year integra? Does it matter if its coming off a 2 or 4 door? Or are they all the same?
Old 02-18-2009, 11:44 PM
depends on the year...
Old 02-19-2009, 06:43 AM
ffa710's Avatar
Do you know what years will work?
Old 02-19-2009, 09:14 AM
Redbone's Avatar
did you read the FAQ section at the top of the page? https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-complete-rear-disc-brake-conversion-how-w-parts-pictures-56k-haha-641639/
Old 02-19-2009, 09:25 AM
siblue_gzer's Avatar
i used 94-01 integra rear disc and ebrake cables for my ek and it works. fits perfectly. u don't have to piece it together, all should fit right in.
kulo's Avatar
i have complete ek rear disc setup fo rmy ek3 hatch
i have 262mm rotors upfront with ABS and rear drums
the ek rear disc setup is NON-ABS
how do i keep abs
or do i remove it?
Old 02-19-2009, 10:52 PM
ffa710's Avatar
Thanks for the info guys
Old 02-19-2009, 11:02 PM
andoxviii's Avatar
Yes, and we have all the time in the world to be on h-t marketplace to find your brakes...
Just go to your local junkyard, everything will be there.
Old 02-20-2009, 01:48 PM
-=Zeqs=-'s Avatar
Did the exact same thing on my brother's project hatch, and the same thing on my coupe. Just reused my stock LCA rather than the teggie ones.
how do i keep abs
or do i remove it?
If you are using a ABS set on a non-ABS car, the ABS just doesn't work. No biggie.
Old 02-20-2009, 02:38 PM
just went to two pick n pulls, here in CA. there is not one car thats over the year of 90'. what junkyards are around you? haha
Old 02-20-2009, 07:12 PM
JHP
JHP's Avatar
^ yeah man i know what you are talking about. Here in so cal i usually only see crap cars at the junkyard. the few times ive seen ek's they have just been molested..... Nothing that can be used is left. :-( Everytime I hear that people back east go and get parts of a SI or something it just makes me wonder if they are bs'ing or if they really are lucky.
Old 02-20-2009, 07:43 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Junkyards around here are gold mines. Here are some things I've found:
Carbing cooling plate (ek) = $FREE!!
CTR 5 lug with CW wheels = $300
Si cluster = $30
ITR 22mm rear sway bar = $20
Several full GSR F/R brake setups = $50-75 each.
E-brake cables = $7 each
CTR shift boot = free
100% MINT Del Sol seats = $40 for both (found several times)
99+ spec Miata rear LSD = Did not buy (I told someone else to get it...IIRC, they walked out with it for $200ish?) The car also had the 1.8L still in it and intact...with trans.
26mm Si front bar and LCA setup = $50 with endlinks. Found twice.
Skunk2 coilovers = did not buy
Tokico blue shocks all 4 = did not buy but found 2 or 3 times.
S14 5 lug complete conversion = $200 even though THEY pulled it off the car for me.
Red EM1 side power mirror = $25 (did not buy, though)
300ZX brake conversion (rear) with cross drilled rotors = did not buy
Racing Hart wheels for MSP = Did not buy (would have been ~$100)
ITR sedan rear seat = $20
Champ white painted EM1 with ALL body work 100% intact (theft recovery that just got set down as I got there. Me and my friend stripped that car within like 1 hr lol. That's where I got the CTR 5 lug and other misc awesomeness)
I also saw a Prelude VTEC with the H22 still in there. Looked intact.
We see D series VTEC engines all the time. The complete heads are $80 each.
My friend took the valve cover off a GVR4 that we found...
I could go on like this for days. My wheel bearing just went out on my EM1. I found an EX spindle with a BRAND FREAKING NEW wheel bearing allready installed. This was 3 or 4 days ago $23
Quick Reply: EK drum to disk brake conversion
