98 LX window will not roll up/down... Bad relay?
As stated, the drivers window will not roll up/down with the window switch. I have replaced it with 3 others and still the same thing. The other 3 work fine and the drivers window will work if you jump the wires on the harness plug. I am thinking it could be a bad relay since replacing the master switch 3 times did nothing. Anyone else have this problem? All fuses are good...
Re: 98 LX window will not roll up/down... Bad relay?
i have a 98 ex. try pulling out the fuses and replace the windows relay anyway. it looks like its not blown, but the contacts are wearing. this worked for me, amazingly as the friction of pulling it out, and putting it back made a clean contact spot and windows worked much better! fuse cost like 3$ and you probably should replace most of them anyway.
