teaser of project
teaser of project
so i got my engine back today... well i got it back in pieces. like the rods were not in the block nor was anything else.... so started at about 8pm tonight and stopped around 2am... i have the engine togeather mated with the trans and completely bolted into the car.... and now it is time for some sleep....
Re: teaser of project
Pretty cool thus far. I see you used an OEM Honda timing belt, curious what other gaskets, rings, seals, even tensioner/waterpump etc. you used in the process.
yeah it was mostly a stock rebuild.... had the head worked and added crower cams and dual springs Arp rod bolts and head studs.
honda- timing belt, water pump, oil pump, valve cover seal cam seals
built for about 8-10psi of boost.... engine was a little worn out and smoked a little at higher rpms
this is going to be my DD
kev
kev
Grannyscivic
13
03-13-2018 01:28 PM
PoorDad
09-19-2011 09:00 PM
rob_d16y8
03-18-2009 11:49 AM
Ramma
05-15-2008 07:34 PM
