Little advise please..Oil on 1 sparkplug!!
Old 02-19-2009, 03:48 PM
jdmkris's Avatar
Default Little advise please..Oil on 1 sparkplug!!
ok i have a turbo lsvtec and trying to figure out what is causing the fouling on 1 spark plug on cylinder #2..when i took out all plugs that was the only one with burnt oil..idk if this helps but i also have a oil sitting between the exhaust ports of cylinder #4 and #3..i dont think its the valve cover gasket thats leaking the oil down to the manifold..and when i turn on the car in the mornings it smokes alot of white and seems like its burning up the oil..BUT it goes away after driving for about 3 to 5 minutes and no white smoke anymore til next morning when car sits. can anyone point me to the right direction so i would know wether or not to send the head to the machine shop.also,this happened after i tuned the car on a dyno.
thanks
Old 02-19-2009, 03:57 PM
pemd5555's Avatar
Default Re: Little advise please..Oil on 1 sparkplug!!
you got a leak!! haha check valve seals and piston rings
Old 02-19-2009, 04:00 PM
yoshi-ua's Avatar
Originally Posted by pemd5555
you got a leak!! Haha check valve seals and piston rings
x2
Old 02-19-2009, 04:06 PM
jdmkris's Avatar
Originally Posted by yoshi-ua
x2
ok and how much would it normally cost to get it fixed?
Old 02-19-2009, 04:35 PM
jdmkris's Avatar
one more thing..can anyone direct me to a specific link as to how to change the valve seals..i searched and got no luck finding it. thanks
Old 02-19-2009, 07:03 PM
joelmatt89's Avatar
are you sure that it is oil, do a compression test and leak down. I'm just throwin this out there it could be bad injector and the plug is fouling from running rich, are you consuming oil. You don't want to just open up your engine if your not sure about that
Old 02-19-2009, 08:26 PM
nengx07's Avatar
i just did my valve stem seals.. if i find the thread about it again ill give u the link.. somehow my search engine isnt working..
90hondaccord
05-25-2014 10:42 PM
Brandi18c1
01-22-2013 07:11 PM
jdmkris
02-19-2009 05:32 PM
n1_ek
08-26-2003 11:12 PM
Quick Reply: Little advise please..Oil on 1 sparkplug!!
