Map Light Install: Popping Fuses?
Old 02-19-2009, 12:45 PM
Kyoh's Avatar
Default Map Light Install: Popping Fuses?
Yoyo, Got a maplight off my '94 GSR sedan and I'm trying to install it in my '93 Ex Coupe. I already had the mounting bracket for it so it all bolted up but as soon a I hook up the power wire to the 12v constant for the dome light, it pops my fuse. Gone through a few fuses now trying different things. Why won't it just work?
Old 02-19-2009, 12:57 PM
john666's Avatar
Default Re: Map Light Install: Popping Fuses?
touching metal and grounding and popping a fuse perhaps ? or maybe just wrong wires ?
Old 02-19-2009, 01:01 PM
Kyoh's Avatar
I tested the wires I'm hooking it up to. Definitely the dome light's 12v. I'll check to see if its ground out anywhere...maybe tape off the whole housing. Thanks for the reply!
Old 02-19-2009, 07:23 PM
BlueIntegraBoy's Avatar
Sounds like you are grounding out the 12v wire. I did this install in my old 92 Civic. I tapped the white/blue wire running down behind the a-pillar cover.
Old 02-19-2009, 09:47 PM
Kyoh's Avatar
Yup Yup, The wire I ran for the 12v was being pinched by the sunroof motor. It's a pretty tight spot. Taped it up and re-routed a little bit and everything works now. Looks almost stock. Thanks for the help guys!
mdog244
15
01-02-2018 05:25 PM
SHG_Mike
11-22-2006 11:53 AM
clutch33
05-04-2004 06:10 PM
clutch33
05-04-2004 04:55 PM
turbolag98
08-02-2003 05:37 AM
Quick Reply: Map Light Install: Popping Fuses?
