HELP: installing shift light
is there anyway to install my shift light without using an after market tak? i was wondering if it could work by using the tak off my cluster... if so how would it be wired??? any help appreciated
Re: HELP: installing shift light
if you got one of those shift lights that has the chip that you put in the back to go off when it hits the certain RPM it could work. You would need a relay to power it but you could just tap that into the line sending the tach reading to your cluster, put one wire for ground, and you would need a relay or a different power source to power the light...
www.phearable.net
Their chipped ECU's use the CEL as a shift light, specified by the buyer on purchase.
Other than that you could get a shift trigger from Summit racing and use an LED....
-XLR8
-XLR8
it can be done the best way is to buy the auto meter tach light that has the pill in it and you can just change the pill out to different shift points ,if you have a light already with no shift light you can tap the driver side harnes point ,The wire is blue or green on the driver side tower .You will need to run an inline pill with the set shift point and run it to the tach light,I would get the auto meter tach light ,much easier
5po0n_Dc2
01-04-2006 01:48 PM
5hipht_Ent
15
12-08-2003 07:03 AM
