Yay! another cel post!!
ok, so i went to check my cel with the self checker and when i shorted the 2 wire plug my cel just stayed on. it flashed on then off like normal without the paper clip. any tips?? thanks
Re: Yay! another cel post!!
mine does that sometimes, just turn the car off, take the wire out, put it in REALLY good and make LOTS of contact, then turn the car back on
edit :welcome to the CEL party
how do i reset an ecu? and i actually dont know what obd0-1or2 means. i've heard it alot but i never got a really good explanation. and ya, 95 del sol si
well 95 means obd 0 or 1, obd is on board diagnostics. the batt needs to be disconnected and take the top second to the right 7.5 amp fuse out of the fusebox under the hood. wait about 20-30 mins and then go connect everything back. then check the CEL.
there has to be contact between the two wires to read the code. If it is staying solid even with the plug jumped, then that means the ecu is fried. Take the top of the ecu apart and see if you notice and burnt resistor, caps or traces in the board, Top and Bottom
to the OP, does your car run?
If you jump the connector and the light doesnt come on, that means there are no codes. It could also be that the common grounds are not contacting properly.
https://honda-tech.com/forums/forced-induction-16/solid-check-engine-light-service-connector-jumpered-460808/
make sure you are jumping the plug then turning the ignition on
My bad slowhatch. The solid even after jumping can mean no codes It can also mean a FUBAR ecu.
https://honda-tech.com/forums/showthread.php?t=460808
Yea I will cross my finger for the OP. I was reading the thread link I posted and they jumped the ecu with car off and got codes. Also OP make sure you ecu/backup fuse under the hood is good or once you shut the car off to check the codes its reseting the ecu...
my laptops actin really dumb or id explain the whole story but long story short- my problem i was havin is gone and there is no cel comin on while i drive so were good now. thanks for all the help.
ragnaroek
11
07-26-2005 05:33 AM
