weird problem.
weird problem.
ok, this problem is gone now, but i'd still like to know what caused it.
i started the car to go to work in the morning, the car started with the grinding noise from the tranny, and the dash lights became dimmer at the same time. so i got on the road and everytime i step my foot on the clutch, it will make the grinding noise and dash lights will become dimmer again, and i noticed the speedo will drop same as the rpm gauge. so i just drove in 5th gear all the way, until i got to work. i shut off the car after and restarted it again and problem went away.
btw, i got a 96 dx coupe.
does anybody knows what the cause might be? any input will be greatly appreciated. thx! HT!
Re: weird problem.
that could be a few things the grinding noise could be a throw out bearing or release bearing that is going bad. when you said the speedo drops the same as the rpm gauge are you meaning the backlighting or the actual needle
Re: weird problem.
the lighting will become dimmer and the needle will drop too.
DaveSi677
11-04-2008 07:18 AM
fleaEG
10-18-2007 02:34 PM
slowpokecivic
09-30-2005 01:59 AM
