Civic failed emissions horribly
Old 07-29-2009, 02:07 PM
New User
Slow_Ej1's Avatar
Icon6 Civic failed emissions horribly
I took my civic to get emissions done and here are the results
25/25 Test Reading----------Allowed
HC ppm----402--------------147 Fail
CO %------2.03-------------0.82 Fail
NOx ppm---1413------------1072 Fail
RPM--------2024------------3000 Max
CO+CO2----15.08-----------6.00 Min
50/15 Test Reading---------Allowed
HC ppm----364--------------152 Fail
CO %------1.40-------------0.85 Fail
NOx ppm---1453------------1186 Fail
RPM--------1860-----------3000 Max
CO+CO2----14.92-----------6.00 Min
what all should I change/use to get it to pass? sorry if this is the wrong forum
Georgia
95 civic Ex
d16z6
CEL is NOT on..
Old 07-29-2009, 02:14 PM
90Rexx's Avatar
Default Re: Civic failed emissions horribly
blah.... well lets start with what state your from, what car you have, year make model engine and mods and if there is a cel
Former User's Avatar
Is the CEL ON? The engine seems to be running rich and the cat may be bad. When did you last replace the plugs, wires, cap, and rotor and set the ignition timing?
Old 07-29-2009, 02:16 PM
New User
Slow_Ej1's Avatar
Georgia
95 civic Ex
d16z6
CEL is NOT on..
Old 07-29-2009, 02:19 PM
90Rexx's Avatar
like ronj said start with a tuneup then. it appears either your engine isnt burning the fuel properly, or your catalytic converter isnt burning enough leftover fuel. hence your HC and nox is high....
Old 07-29-2009, 02:35 PM
97ej6dx's Avatar
OR move to a diff state that doesnt check emissions !! Its much easyer than trying to comply with them.. lol
Old 07-29-2009, 02:37 PM
90Rexx's Avatar
well that wasnt very technical, or useful
Edit:
WOOT this was my 1,000 post!!
Old 07-29-2009, 06:33 PM
New User
Slow_Ej1's Avatar
Ill be sure to start with the tuneup
I wish.. lol
Old 07-29-2009, 07:16 PM
New User
Slow_Ej1's Avatar
anyone else? help?
Old 07-29-2009, 07:34 PM
powersk8er92's Avatar
Exhaust valve lash? maybe? IDK just a different guess.
Old 07-29-2009, 07:56 PM
97ej6dx's Avatar
Not technical but its an option. but for Technical help. Id remove any after market fuel pump. Replace your cat. and be sure both O2 sensors are working properly. But if there is no CEL then there may not be an O2 sensor problem. If you have a Walbro 255 then that cranks more volume of fuel in there at the same pressure. the pressure regulator only controls the pressure but the volume will still change depending on the liters per hour your fuel pump can handle. Check your sparkplugs and be sure that they are clean and the spacing is correct. If they arent burning as much fuel as they are supposed to that could be a problem. possibly get larger diameter sparkplug wires.
Perhaps an oil change may help also. fresh oil so the motor doesent have to work as hard to turn with old oil
Old 07-30-2009, 05:09 AM
90Rexx's Avatar
riiiiiiight.... start witha tune up lol
Old 07-30-2009, 08:59 AM
lovelove's Avatar
Georgia does smog emissions???? i didnt know that. my answer to your prayers would be to try SEAFOAM. i heard its pretty darn good.
eghatch9295
14
06-08-2016 04:10 PM
CherokeeInk
12-15-2012 10:15 AM
Ericdf132
10
10-01-2012 06:08 PM
95jeremie
10
07-08-2009 07:25 AM
Vertex Spirit
08-29-2008 09:19 PM
Quick Reply: Civic failed emissions horribly
