what ecu should i get?
im running a jdm b20b right now and its running a auto p06. idk if it is chipped or not though. what would be a better ecu to get?
I'm not Rick!
Re: what ecu should i get?
po6 is good. you can convert it to manual with like 1 or 2 resistors. you can also add vtec to it if you ever slap a vtec head on it. i would recommend haveing it socketed and put a chip for base map b20 in it
I'm not Rick!
you can use any obd1 ecu.
if you have vtec you need a vtec ecu. or you can add vtec to it
you can convert at to 5spd
the only dif would be the amount of fuel that is put into the motor
thats why i would just get any ecu you have and have it socketed and put a b20 base map in. but for the b20 ecu. take it thats cheap.
I'm not Rick!
ebay. theres a guy that makes chips for $20. i had plenty and other friends of mine had them also. they work like perfect. you buy the chip. then message him what ecu and you want a b20 base map.http://cgi.ebay.com/ebaymotors/p28-c...Q5fAccessories
