d16y8 timing?
d16y8 timing?
I just changed my distributer and I need to know what the stock timing degree is set at, I tryd searching but its limited on my blackberry, thanks
Re: d16y8 timing?
so I set my base timing to 16deg on my 99 ex y8 would that trip my knock sensor at around 2100 rpm? sorry for my ignorance in ignition timing
ps I will be setung it to 12 deg in the morning
Re: d16y8 timing?
Among the 96-00 Civics, only the Civic Si with the B16a2 engine uses 16-degrees BTDC for the ignition timing. All others use 12-degrees BTDC, regardless of transmission.
Just set the ignition timing to the red mark on the crank pulley. Then you'll be good to go.
