code 22 (vtec pressure valve) help..
well i had my car running for awhile now and iv had no problems crossing vtec over till last nite...i hit vtec and after that my check engine went on and notice my vtec wouldnt crossover...so i did the procedure for check engine lights and got code 22 vtec pressure valve...how can i fix this?...do i have to change the whole silinoid or could it be wiring...i need help
Re: code 22 (vtec pressure valve) help..
im running an lsvtec with p28 ecu with an lsv basemap...it just went on when i recently hit vtec...as for oil i just changed it and my oil level is good...
well honostly after i did change my oil it was good but i didnt really add extra for the vtec oil line or whatever and then after i did hit vtec it went on...and then i added some oil...yah kinda idiotic but thats y im asking for help...how would i measure oil pressure...do u think its wiring or my solenoid went out?
So now you have topped off the oil, right? The next step is to clear the code from the ECU and go drive the car again. Maybe the code won't return.
Sounds like a wiring issue to me. Lacking the 30 mL of oil that fills the LSV line won't be enough to prevent vtec engagement. Trace the wiring from the solenoid to the ECU. See what you come up with. Clearing the code is at best a bandaid.
Edit: So I see the oil level is fine and the code is still thrown. You can test the circuit and measure the oil pressure as detailed in the service manual.
so hitting vtec could cause my circuit to get all screwed up...and with a multimeter do i test in ohms or in volts...black tip to ground and red tip to the pin correct? and another thing do i check from the obd2 plug where my vtec wires were wired in since i have the conversion harness to obd1
my motor was rebuilt but iv been driving it for almost 5 months now without that code and my vtec was working till couple days ago when it came on...so rite now iv just been driving it without vtec...which sucks haha
could be a loose wiring.. check that first.. if you still cant figure out the problem then just bypass it.. its easy and alot of people do it including me. Mainly for jdm motors because they dont come with vtec pressure switches
Here you go sweety.
http://www.phearable.net/tech/wiring/vtpsbypass.gif
Theres nothing wrong with running your setup like this. Ive been doing this for 4 years and no problems!
I have the same code 22. Let me know if bypassing the vtec pressure switch makes your vtec kick in. Ive had this code for a couple months now.
do it.. it will work but first thing you need to make sure is that you have proper engine oil filled up and make sure there isnt any other problems before you go and do this..
