air/fuel gauge help
air/fuel gauge help
so i got the gauge hooked up. i tapped into the white wire after the clip so its tapped into the engine harness side. but the lights dont come on until i rev past 4k.. when im idleing nothing is coming up. i would try to tap into the wire on the ecu but i cant find wire diagrams anywhere. i have a p06 computer. is this normal? i thought when you hook it up it should light up all the time while the car is running.
I'm not Rick!
Re: air/fuel gauge help
dude.... what are you doing? please elaborate
that white wire is for datalogging i think or is that the blue wire
are you talking about tapping into the o2 sensor to read it?
im tryin to get my a/f gauge to work right. i tapped into the white wire on the o2 sensor but on the harness side.(after the clip) but the a/f gauge only reads when im over 4k rpms. did i tap into the right wire? i was thinkin about tapping into the wire on the ecu to get a better reading. but idk what wire it is..
so your installing a bling gauge? Sounds like a narrowband gauge judging by the OP.
If you want somthing that'll actually work and be accurate look into AEM or Inovate afr gauges
wutiteez
12-01-2006 06:06 PM
boostng r
09-18-2004 10:57 AM
wickedxboi
03-10-2003 05:37 PM
