VTEC engages at 6000 instead of 5500?
I have usdm b16a2 swap and the previous owner told me it has a type R ecu, do you think thats whats causing the higher vtec engagement?
Should I put a b16a2 usdm ecu in it?
Re: VTEC engages at 6000 instead of 5500?
I think VTEC is 6 on ITR's. Look here.
B18C5
VTEC
Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
Displacement: 1,797 cc (109.7 cu in)
Compression: 10.6:1
Bore: 81 mm (3.189 in)
Stroke: 87.2 mm (3.433 in)
Rod Length: 137.9 mm (5.429 in)
Rod/Stroke Ratio: 1.58
Power: 195 hp (145 kW) @ 8200 rpm & 130 ft·lbf (180 N·m) @ 7500 rpm
Transmission: S80 w/LSD
Vtec engagement @ 6,000 rpm
B18C5
VTEC
Compression: 10.6:1
jollyhonda
07-08-2017 07:15 PM
