How do you remove rear plate garnish on the del sol????
I have all the nuts out.. and theres the 2 tabs.. and i dont want to flex this bad.. can i punch those out with a punch or whats the simple trick on gettting these out???/
Thanks
Thanks
Re: How do you remove rear plate garnish on the del sol????
its just the rear plate frame to come off??? shouldnt need a pic its simple understanding.. what you bolt your plate too.. how do you get that whole piece off after removing all the nuts
by rear plate, theres the the round bolts that you need pliers to remove, but I used a dremel and cut them off from inside the trunk,
exactly thanks alot.. cool ill see what i can do. but so those just spin off your saying.. or just cut to the point
when i cut them off (inside of trunk), I cut around them nut (not through screw, you notice a difference if using a dremel), then used pliers to twist it off, If you do it right away when still super hot from cutting tool, real easily to spin off,
but if you got a badass cutting tool cut the whole damn thing off (nut and bolt)
ok cool just bought one yesterday and my air compressor so cutting them things off.. thanks alot
no problem it was funny, cause i had thte hardest time removing that plate today to change my rear bumper, and every now and then( once a year), i check this site and what do you know
FredrikL
07-11-2009 06:00 AM
_Spugen_
01-05-2005 08:47 AM
dseriessol
03-14-2003 02:42 PM
