d16z6 motor on d16y7 transmission ???
Old 08-03-2009, 11:08 AM
bzoe1's Avatar
Icon3 d16z6 motor on d16y7 transmission ???
i have a broken d16y7 motor so i am looking to buy a used d16z6 and attach it to my d16y tranny will this work and what all will need to be swapped ?
Old 08-03-2009, 11:17 AM
tsdenny's Avatar
Default Re: d16z6 motor on d16y7 transmission ???
its better just to get a y7 again.
you will have to convert to obd1
if you want vtec you should get the y8
Old 08-03-2009, 11:22 AM
Psychoteen101's Avatar
It will bolt right up.
Old 08-03-2009, 11:25 AM
bzoe1's Avatar
yeah its slim pickens all the other moters at the junk yard are busted up this d16z was the only one worth considering. what is obd1?
Old 08-03-2009, 11:27 AM
92ehatch's Avatar
pre 96 cars are obd1 96+ are obd2
on board diagnostics.
basically your car is obd2
if you try to put an obd1 motor in it wont work unless you convert your car to obd1
to do the z6 you will need an obd2 to obd1 conversion and a p28 ecu
and wire in vtec
and i dunno what else exactly
Old 08-03-2009, 12:05 PM
bzoe1's Avatar
so i should try to find a 96-00 engine and there wont be a issue?
Old 08-03-2009, 12:44 PM
apexi_rsx's Avatar
yeah because u would have to swap oil pumps and timing gears on the lower for the crank sensor. then if ur y7 head is salvagable throw it on the z6 with a new headgasket. use the z6 intake manifold but not the injectors. thats the only way it will work and bolt rite up. if u use the z6 head. u need to wire for vtec and get chipped obd1 ecu and a convsersion harness from obd2-obd1. your y7 dizzy would need reamed out alil so u can adjust it. only one bolt will line up but it saves u 30 bux buying another conversion harness for the dizzy... take ur pick...
ratchetEDsedan
02-28-2017 01:32 AM
D-NWI
05-14-2010 02:56 PM
ek_chris
14
10-31-2005 06:55 PM
lv6l
09-22-2005 10:42 AM
1hotvtec
10-12-2003 07:29 PM
Quick Reply: d16z6 motor on d16y7 transmission ???
