b18 swap code6(ECT) and code14(IACV) HELP
95 cx b18a1 swap
still have codes 6(ECT) and 14(IACV) after checking both the sensors and wiring
the plugs were swaped when i iniatially started the car but i have since then rewired them correctly. also the fan wont come on. this has me stumped, according to the manual it should be fine. help is greatly appreiated
Re: b18 swap code6(ECT) and code14(IACV) HELP
95 cx b18a1 swap
how could you have those two plugs swapped if they're nowhere close to each other on the motor? or do u mean swapped but not with each other? as for your fan not coming on check to see if it works by jumping the fan switch plug on the thermostat housing, disconnect and brigde the two pins with a wire, if it comes on, change the switch.
and the fan comes on when i jumpper the plug for th switch
as for your fan, you said it comes on when you jump the plug for the switch, then i'd say your switch is bad, get a new one..
i replaced the ect sensor with one that tested good after i rewired, i did fry the first one
the iacv tested good and so did the voltage at the plugs
smokey.23
08-20-2009 06:26 PM
Fastrax203
07-20-2005 06:38 PM
