Good Suspension For h22a hatch
Re: Good Suspension For h22a hatch
you never wanna cheap out on setups, just save your money and get a good setup. i would recommend the "TEIN Flex", it's adjustable for smooth rides when you want it to be or you can stiffen your ride right before a run at the strip.
PIC Apex's or PIC Selects, adjustable spring seat height and adjustable shock height. Selects come with adjustable shocks as well. PIC will build a set with custom spring rates also so in your case you can have stiffer springs in front for that pregnant motor..haha jus kiddin
i found the ksports for 669.99 where all the pics are well over 1000. so its not to bad on price... are there any good shock and coil setups, other than coilovers
the PIC'S Apex's (what I run) are priced at around $800. If you contact the vendor that sells them in the marketplace he cuts you a great deal. I got mine for $750 shipped to my door. I read on a thread on here somehwere that the Ksports, PIC's, Omni's and some other coilovers are all stamped out of the same factory. PIC however ttears them down and uses higher quality guts and better springs. Dunno if this is true but mine ride amazing. As far as shock/spring setups, at one time I had Tein Stechs on KYB AGX struts. They were nice but the best I've felt is probably Eibach Sportlines on Tokico Blues. You won't be very low on those though. Good luck!
i was wondering if 90-93 accord shocks and spring will work. those should be heavy duty enough to support the h22a since its a direct boltin on those chassis. has anyone tried
i want to emphasize 'quality' in this statement. im running just mediocre coilovers with dropzone struts and the moment and hate it.
take the time, research, and save for a good setup
your *** will thank you
well im askin if they will fit cuz i got h&r full coilovers that came of a 90-93 accord. is there a way to make them fit cuz it looks almost identical in height and all
so if i were to guess i would say no.
but you can always try and post results
well then thats what im goin to do tom. i hope it works cuz that will save me alot of money... anyone use those h&r's
i have to beg my girl freind to ride in my car on just skunk2 slip ons, she says its to stiff and bouncy
AND DONT GET TOCKICO BLUES ON A LOWERD CAR!!! they will blow up and ride like ***, they were not made for lowerd cars.
ok so far i have done the fronts. i have the accord h&r's on the front of my civic...i had to use the top and bottom mount off of the civic with the accord setup. its seems really nice so far stiff but not bouncy. i have to do the rear still which is really really bouncy compared to the front now. i hope the rear work as well as the fronts do. o and the only thing wrong is that the brake line cant be mounted to the shock cuz of different angles but they rnt goin to hit anything so should be ok there
well i have search online everywhere and everyone said that the accord setup would not work and i just put them on my civic so it looks to me like they worked good. i had ebay sleeves on stock shocks slammed and now i have the h&r's from an 90-93 accord on there with more room to lower and its sitting at the same height as the slammed sleeves. cant wait to do the swap and c how it rides... very stiff ride so far but they still need to break in a bit
Progress specifies only certified high-tensile SAE spring wire materials. Our springs are cold-wound on modern CNC coiling machines, then stress relieved, pre-set, and shot-peened for maximum durability.
Features
-Front drop: 2.0" --- Rear drop: 2.0"
-Front rate: 375 lbs/in --- Rear rate: 175 lbs/in
-Limited lifetime warranty!
-All spring kits are powdercoated metallic gray.
Notes
-Actual product may be different than pictured
-These are designed specifically for Civics with H-series motor swaps
Downloads
Features
Notes
Downloads
i have function form t1 coilovers on my h22a sedan and their a real bang for the buck. invest in front upper strut bar and rear upper really tightens **** up..
2point2
22
06-29-2004 03:39 PM
accord, civic, front, good, h22, h22a, hatch, honda, racing, road, springs, suspension, suspensions, transmission, withstand
