headgasket question... plz help...
ok so heres the problem... i recently did my headgasket and i followed each step by stepp... i finished the car started right up but i have no power at all while driving cars bogs horribly... the car car is not throwing smoke or anything but after a while of starting up my oil leaks from between the head and the blockk. i brought the head to a machine shop to get resurfaced and i did the torque specification to 67 ft pound...... so here is my question... is it possible that the head got resurfaced un evenly?? have this happened to anybody before??? plz help....
Re: headgasket question... plz help...
thank u for your help on my tread . I recently did a head gasket job on my friends car now. did you follow the 4 steps torque spec? are u using ARP studs or did you used OEM head bolts? , Did you set your timing mark right cuz if not that could be it.
im using the oem head bolts and yea i did followed the 4 step but what i didnt do was go back and torque 1&2 one last ime or is that not necessary? and yep the timing was just barely off but it was on...
copper spray is your friend, even with copper spray the there still might be some leaks, also if you you are having bogging problems it could be because of the timing, which usually results in you having to do the timing belt again.
ok so i tried to torque 1 & 2 down one last time... and it still leaks from between the head and block.... =[
so anymore ideas of what i should do??? or should i just buy a new head and go from there?
hows your ignition timing and mechanical timing? if your a little off itll run like ****. what kind of headgasket did you use, did you follow the torquing order
Ignition timing should be checked along with mechanical timing. I would blame the used headbolts if everything else checks out.
ok so thats two people who says used headbolts is the problem... well im gonna try changing them then and see what happens... and no i did soaked them in oil.. is that recommended?
how much is the oem headgaskets?? cause i paid about 60 for the fel-pro and i was told that it meets the requirments of a oem one....
ScubaStevo80
01-11-2005 01:08 PM
