h22 ek immobilizer problem
so i recently h22 swapped my 99 si. its supposed to be out of a 97 lude that was previously in a civic but idk that it ever actually ran just know it was in there. so i have the motor in the car and harness all connected and not getting spark or fuel. i am new to an actual swap bc normally i just mess with the b16s that come in my civics. i am guessing reason for no start is immo. i am running the comp that came with the motor.like i said it was in a civic previously but dk if they had this problem or not. i have a p28 with jumper that i ran for my b16 but dk if the h22 is obd2a or b and dk which the jumper is. like i stated above it was for my b16a2 im sure someone will have more knowledge about this. but mainly i would like to see if there is a way to make the car start without getting a basemap for the p28 and using the ecu i received with the motor. i have been reading about ppl having the same problem and ppl are saying to break the immo off and it will run and some are saying that will not work. i do not wnt to go to honda and buy a rediculously priced key so any info will help.thank you
Re: h22 ek immobilizer problem
what shape is the wiring harness in that you got with the swap? is it all cut up and spliced or all nice? i would start with the wiring and make sure everything is right first.
