EG JDM yellow fog lights, drivers side brighter than other side???
Old 01-09-2011, 07:23 AM
EG-SIXV-TEC's Avatar
Default EG JDM yellow fog lights, drivers side brighter than other side???
i just installed EG replicia jdm yellow fog lights from jhpusa. that got for Christmas new in a box never been used. i installed everything properly and it seems the drivers side is brighter than the passenger side lights.
the passengers side fog is lighter clear cant see any lines on the ground and the drivers side fog light seems to have a yellow line of reflection on the ground and brighter. why??
Old 01-09-2011, 07:32 AM
The Grumpiest
grumblemarc's Avatar
Default Re: EG JDM yellow fog lights, drivers side brighter than other side???
Maybe the fact that they are "replicas" might have something to do with it.
Old 01-09-2011, 07:56 AM
Seagull Management
94EG8's Avatar
Probably a poor ground on the dimmer side.
Old 01-09-2011, 08:05 AM
MonkeyMagic's Avatar
probably one is aimed at the ground.. the other at the fair blue sky.
Old 01-09-2011, 02:19 PM
eh9deux's Avatar
What he said. Take off the covers and one of the screws is the adjuster screw. It's usually the bigger one.
Old 01-09-2011, 03:22 PM
RyVcZ's Avatar
yup you could easily adjust it using a screw driver. you should have aligned the aim of the light upon installation
Old 01-09-2011, 04:48 PM
Luis407's Avatar
Wait till the suns going down pull up close to your garage door leaving enough room for you to work. Turn on the lights and you should be able to tell if there lined up or not. If that's not the case then I would go on to check your voltage to each light then make sure there grounded right.
dubeedoo209
04-02-2008 08:57 PM
poormans_typer69
01-18-2007 10:54 AM
Screamer
08-03-2001 03:11 PM
Quick Reply: EG JDM yellow fog lights, drivers side brighter than other side???
