**NEED HELP W/ LS-V SWAP INTO DEL SOL**
Okay, I am going to buy a ls-vtec motor, and going to drop it into my 95' del sol-s. I was wondering what do I need to do the swap.
THIS IS WHAT MOTOR WILL COME WITH:
head: b16a
block: b18b1
trans:b16a
goodies:
intake mani:type r
type r throttle body
spoon gasket
10mm spark plug wires
new spark plugs
DC headers
new clutch
new flywheel
new head gasket
gsr cams n gears
shift linkage with short shifter
new radiator n resavor
Does not come with axels, wire harness and ecu
So what axels, wire harness and ecu do I use? Also what else do I need to do the swap?
Thank you in advance for your help
head: b16a
block: b18b1
trans:b16a
goodies:
intake mani:type r
spoon gasket
new spark plugs
DC headers
new clutch
new flywheel
new head gasket
gsr cams n gears
Re: **NEED HELP W/ LS-V SWAP INTO DEL SOL**
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-ls-vtec-truth-behind-power-2587855/
Read and learn
Searching helps too
Read and learn
Searching helps too
cody_sandlin
08-09-2013 05:19 AM
da_driver_15
12-25-2010 12:23 PM
roque-pr
19
03-24-2010 05:21 PM
spunky424
08-15-2006 08:25 AM
