power locks
power locks
My car has power locks but the driver's side doesn't work. You can lock it by hand or with the key just not with the button or keyless entry. What would cause this?
Re: power locks
BUMP^ I am having a similiar problem with my passenger side. It unlocks with key or by hand, although with some difficulty and it always tries to relock itself if the handle isn't opened in time. It just gets stuck in a vicious cycle if I try to use the power locks, it clicks as if trying to unlock and then doesn't move the latch so the system automatically relocks it a few times.
Re: power locks
i've asked this before but i'm too lazy to look it up again. what would cause the door lock to not lock manually but works fine with the key and the remote?
Re: power locks
Re: power locks
do you have an aftermarket stereo installed by any chance?
Im having the same problem. Not having the stock radio causes problems with the keyless remote correct?
Re: power locks
My car does the same thing but it's my driver side that's messed up. and I have a sedan and my back doors don't work either. only the passenger one.
Re: power locks
not to jack ur thread but im having a similar issue. when opening the car door from the outside with the key, only the driver's door opens. also the door lock switch inside on the driver's door does not work so i figured it was the actuator.
can somebody post pics of the actuator and its location inside the door? I pulled down the doors of my 2000 Civic Si Coupe but i'm not sure what it looks like or if the actuators are even in my doors
would be a big help. thanks!
Re: power locks
That is correct. One most models, you need to have the stock radio in order for the keyless remote to work.
humble007
09-12-2005 12:10 PM
humble007
Audio / Security / Video
09-12-2005 12:10 PM
