help... b16a2 into eg body
i have a b16a2 swap... everything is there ... motor... tanny... axels... shifter links.... and the wire harness on motor.... and all needed to make it run... obd2 to obd1 jumper harness with a p30 ecu.. obd1 ecu.... i got this swap out of a 1999 civic si....
now my question is how do i connect the interior cabin harness to the computer and make it run.. right...... or is it just plug and play...
is there any modification i need to do??? i have the b16a2 whole engine harness and came with the jumper harness to run the p30 ecu but i dont know if it will connect to the cabin harness since its the whole b16a2 engine harness.... help?
or should i stick with the d15b7 harnes that is in my eg civic and just rewire the harness to make it work...???
oneforce
04-24-2006 10:21 AM
