Problem removing front lower control arms - bolt spins
Old 04-12-2011, 02:27 PM
allums34's Avatar
Default Problem removing front lower control arms - bolt spins
i want to replace the front lower control arms but the front bolt just spins is there any thing i can do to get the bolt off
Old 04-12-2011, 02:42 PM
redline1219's Avatar
Default Re: suspension
Put a jack under the control arm and use an impact gun on the nut, this should work fine
Old 04-13-2011, 08:48 AM
allums34's Avatar
the only things the nut in side the sub frame spin also. i thought nut is spot welded to the inside of the sub frame
Old 04-13-2011, 08:53 AM
05foresterxt's Avatar
The lower control arm uses long bolts with nuts at the end. You need to hold the nut with another wrench while taking the bolt off. After that, if it just spins inside the bushing, use a screw driver/pin to knock it out.
Old 04-13-2011, 09:04 AM
Resident Gearhead
BryanM.'s Avatar
He said the welded nut inside the subframe has broken loose and the bolt just spins.
OP I had this happen to me, I ended up replacing the subframe instead of cutting a hole in it to get at the welded nut.
Old 04-13-2011, 09:52 AM
blaze_125's Avatar
I did the opposite. I cut a hole just big enough to fit a wrench on the nut and got the job done.
Old 04-13-2011, 09:55 AM
Arthas's Avatar
Default Re: Problem removing front lower control arms - bolt spins
I held it with vice grips and loosened the nut with a wrench. It took a while but I finally got it done.
Also, be careful with damaging the threads.
myownreality
02-09-2013 10:43 PM
cletus11
03-06-2011 02:17 AM
Tong.Y
06-14-2010 12:33 AM
James
12-23-2003 08:13 PM
Quick Reply: Problem removing front lower control arms - bolt spins
